Wireless Help
Hey, this is opt. I need help with my wireless network. have a d-link usb card in my computer, and it is reconized in my computer. (when i view the properties of My Computer, it's under 'Hardware'). Also, the card is in the system tray, and it's signal stregnth is good. When I go to start -> connect to -> show all connections, Under 'LAN or High-Speed Internet, there is only the 'Local Area Connection' icon. I think that if i can get back the 'Wireless Network Connection' icon, I will be able to connect back to the internet. I don't want to set-up a new wireless network, so the wireless network wizard doesn't help me. So, how do I go about restoring this icon, and connecting back to my wireless network?
Thanks,
opt
nevermind... the problem is a little more serious than i suspected. i am taking the computer into the shop and stuff. it is a problem with the actual wireless card itself. so admins: if you want to delete/close this thread, that is fine with me
