wiping clean the recycle bin
I want to wipe clean the recycle bin but wonder what product to use
ccleaner perhaps?
is ccleaner strong enough to thoroughly wipe recycle bin completely clean??
Yes. It can do it. Only very advanced forensic tools like EnCase can recover a bit of the trace of what you've wiped out with CCleaner.
Normally, CCleaner only deletes and frees disk space. (That's enough for everyone.) But if you want to activate full wipeout (which is naturally slower) you must do it manually from CCleaner's Options section.
