CCleaner wipe utility is nice, but sometimes you get doing other things & forget if you selected 1 pass, or 3, or if you selected only free space, or entire drive.
Wouldn't it be nice if CCleaner always showed during the erase process, a panel that showed what you selected?
Example:
User selected
Erase: Entire Drive
# passes: 3
I myself would love to be able to instantly glance & see what I selected. Sometimes I get very busy, & by the time CCleaner is nearly done, whoa, what did I select in the first place? CCleaner doesn't show it once it begins!
Well, ok, it does show the wipe free space, I think, but what about the # of passes? Isn't that important too?
