Winapp2 Trim.bat problem with 64bit .
Hello
downloaded Winapp2 and installed in all ok, but was slow to load in Ccleaner of course .
Downloaded Trim.bat and ran it from a command prompt and was told not for 64bit Windows <_<
Got it all from here http://www.winapp2.com/downloads.html
hope some bright fellow can help me or give me a link to a 64bit Trim.bat !!
Thanks .
Winapp2 is not a supported product. If you have any questions on it or trim you'll need to ask in their dedicated threads. However there is no trim64. it works fine in 64 though ive done it recently.
Hello
Thanks .
WFM from command prompt as well, but you can run it by simply double clicking it. Make sure trim.bat, CCleaner, and winapp2.ini are all in the same folder.
It should be in .bat file format (trim.bat), not trim.exe.
Thank you so much nodles , its now working . :)
