Winapp2.ini additions
Would make sense indeed. The disk cleaner is an alternative, not a side-by-side add-on to CCleaner.
Yeah, I agree with Tux there that ccleaner is great for making it so you never acutally need to run disk cleanup. so it would make sense to add that entry. I also like that it is false by default. question though, my Windows seven also makes a MinesweeperSettings.xml.bak so those would be left behind after the cleaning, is this by design?
Yes, the gameSetting.xml and gameSetting.xml.bak are for the games settings ie. for Minesweeper the game board size, ect.
I could add them as a separate entry, but I don't see why anyone would want to clear their settings for games.
Anyway here is a new file, added to it are some updated folders, auslogics boostspeed logs, last.fm client cache and the microsoft windows game stats
updated: Removed SRWare Iron and fixed Microsoft Windows Games Stats :)
http://omploader.org...ydw/winapp2.ini
updating the first post with it too.
LOL I read your entry wrong . . or at least made an assumption :P
I only have the settings files and the windowprefs.xml
I don't have what you have listed yet, let me play one game of something so i have a stat file and then I get back to you LOL
what weird though my minesweepersettings.xml does have stats written inside of it o_O
EDIT:
Yup doesn't look like windows 7 is creating those files and it doesn't even looks like the diskcleanup is even emptying the stats from the settings file. (note I only tested on Solitare and Minesweeper)
Still I say yeah add it
Edit: seems my assumption as to the behavior of the saving system was incorrect. I will amend the file to account for this.
You should remove SRWare Iron as it now has official support.
[*Microsoft Windows Game Statistics]
LangSecRef=3025
DetectOS=6.0
DetectFile=%localappdata%\Microsoft Games\
Default=False
FileKey1=%localappdata%\Microsoft Games\Chess Titans\|ChessTitans.xml
FileKey2=%localappdata%\Microsoft Games\Chess Titans\|ChessTitans.xml.bak
FileKey3=%localappdata%\Microsoft Games\FreeCell\|FreeCellSettings.xml
FileKey4=%localappdata%\Microsoft Games\FreeCell\|FreeCellSettings.xml.bak
FileKey5=%localappdata%\Microsoft Games\Hearts\|HeartsSettings.xml
FileKey6=%localappdata%\Microsoft Games\Hearts\|HearsSettings.xml
FileKey7=%localappdata%\Microsoft Games\Mahjong Titans\|MahjongTitans.xml
FileKey8=%localappdata%\Microsoft Games\Mahjong Titans\|MahJongTitansStats.xml
FileKey9=%localappdata%\Microsoft Games\Mahjong Titans\|MahjongTitansStats.xml.bak
FileKey10=%localappdata%\Microsoft Games\Minesweeper\|MinesweeperSettings.xml
FileKey11=%localappdata%\Microsoft Games\Minesweeper\|MinesweeperSettings.xml.bak
FileKey12=%localappdata%\Microsoft Games\Purble Place\|ComfyCakesScoresAndSettings.xml
FileKey13=%localappdata%\Microsoft Games\Purble Place\|ComfyCakesScoresAndSettings.xml.bak
FileKey14=%localappdata%\Microsoft Games\Purble Place\|ConcentrationScoresAndSettings.xml
FileKey15=%localappdata%\Microsoft Games\Purble Place\|ConcentrationScoresAndSettings.xml.bak
FileKey16=%localappdata%\Microsoft Games\Purble Place\|PurblePlaceSettings.xml
FileKey17=%localappdata%\Microsoft Games\Purble Place\|PurblePlaceSettings.xml.bak
FileKey18=%localappdata%\Microsoft Games\Purble Place\|PurbleShopScoresAndSettings.xml
FileKey19=%localappdata%\Microsoft Games\Purble Place\|PurbleShopScoresAndSettings.xml.bak
FileKey20=%localappdata%\Microsoft Games\Solitaire\|SolitaireSettings.xml
FileKey21=%localappdata%\Microsoft Games\Solitaire\|SolitaireSettings.xml.bak
FileKey22=%localappdata%\Microsoft Games\Spider Solitaire\|SpiderSolitaireSettings.xml
FileKey23=%localappdata%\Microsoft Games\Spider Solitaire\|SpiderSolitaireSettings.xml.bak
I had to play ALL the games :lol: but I did it. I will post a revision without SRWare Iron and with this revised entry
You don't have to add extra FileKeys with %ProgramFiles(x86)%
When CCleaner detects 64bit it points %ProgramFiles% to the right direction (in this case C:\ProgramFiles(x86)\)
It's just like %LocalAppData%, CCleaner will automatically point it to %userprofile%\local settings\application data\ on Windows XP. ;)
I'll be a sad panda if Ccleaner did this by default and this was a waste of time, but oh well what can you do.
Are you certain of that? Because to me that would imply we wouldn't need work arounds for default entries like Sun Java for vista/7
Aww I just tested this with few rules and it seems you are right, which is somewhat disheartening. Would it make sense then, to remove all the added things? :( At the very least I did add/update some entries I suppose :lol:
Sticky this; edit the original Winapp2.ini thread.
If your recent test on a FEW RULES shows that a they are redundant, it neither proves nor disproves the value of other rules.
Windows 7, and also presumable Vista, has BLACK HOLES where data disappears over the Event Horizon.
All the rules are broken. Abandon hope all ye who enter ! ! !
I have just posted information on this problem at :-
http://forum.piriform.com/index.php?showtopic=29618
Alan
This is true, I did not check every single path, so I can't assume ccleaner automagically does this for every entry. I suspect things pointing to locallowappdata wouldn't be compatible with windows xp, for example.
I will do some additional testing with one of my windows xp boxes, I suspect that some of the paths at the very least have altered, but I don't know. :)
Aside from that, heres an updated version (with added filekeys still there)
http://omploader.org/vNWZndQ/winapp2.ini
[icon Cache]
LangSecRef=3002
Default=true
FileKey1=%userprofile%\Local Settings\Application Data|IconCache.db
FileKey2=%LocalAppData%|IconCache.db
*** Correction ***
[icon Cache]
LangSecRef=3025
Default=true
So that it will be added under the Tab Applications>Windows
and Not under the Tab Applications>Windows Explorer
(since it can Not go under the Tab Windows>Windows Explorer - where it normally belongs).
It does not.
It does not.
Then, you can make the above Correction (3002=>3025) so that the respective Icon Cache entry
looks like:
[icon Cache]
LangSecRef=3025
Default=true
Thank you for your hard work!
Nice work Winapp2.ini.
This just jumped out to me, though.
[*CleanMyPC Registry Cleaner (Backups)]
LangSecRef=3024
DectectFile=%ProgramFiles%\CleanMyPC\Registry Cleaner\rcleaner.exe
DetectFile=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe
Default=True
FileKey1=%ProgramFiles%\CleanMyPC\Registry Cleaner\UndoCenter|*.*
FileKey2=%ProgramFiles(x86)%\CleanMyPC\Registry Cleaner\rcleaner.exe
FileKey2 will not give the desired result I think.
LangSecRef=3024
Default=True
I know I said I didn't check most of the entries, but judging by the detect file, that on is REALLY bad. :lol:
Someone dun goof'd
I've fixed it in my copy, I'm still testing some stuff though.
Updated: http://ompldr.org/vNWk5Mg/winapp2.ini
Cool, checked and merged with mine and good to go thanks :) I like some of the new adds too (P.s. For next one you can remove realplayer sp it's = to winapp.ini and also the second * on quicktime for vista and seven 1) no longer needs cache new winapp.ini does that correct now 2) doesn't need extra * ) again, Winapp2.ini thanks so much for your work you're awesome.
