Will CCleaner Function w/ SeaMonkey 1.05?
Due to Mozilla being retired with 4 unpatched security holes & with my system specs precluding using Firefox & Sun Java 1.5.0 (aka 5.0), I find myself forced to adopt a SeaMonkey (successor to Mozilla Suite).
Question: Since SeaMonkey will reside in the Mozilla folder (not deleted after Moz. un-install) and all plugins & profiles from Moz. will be retained, will CCleaner(1.33 Slim) still be able to delete ALL 5(?) caches & histories as it does now?
If yes, should I un-install CC & then re-install after install of SeaMonkey (so it will find it OR leave and just accept where it says Mozilla (I should just read SeaMonkey) as OK?.
I LOVE my CCleaner and wouldn't know what to do without it!! Easiest way to clear JavaByte Verify & boot M(ulty)S(py) sneeks!! ;):D
Thanks for speedy & knowledgeable reply as I plan changeover in next few days.. :D
I have been using seamonkey for a few days now and ccleaner seems to clean everything it should. Also just in case your interested there is an extension to give seamonkey firefox clear private data function here:
http://webdesigns.ms11.net/chromeditp.html#2
(also a few more things like a home button!) :)
Just make sure you close seamonkey before running ccleaner.
Thanks for such speedy reply & for the great link. Sounds like this shouldn't be a problem. :D
