Will CC cclean up after me?
Trying to uninstall a program. Its uninstaller fails because of missing file unins000.dat. CC has an entry for the prog but tells me the prog 'does not exist.'I want to just go into its \ProgramFiles directory and delete its fiiles and subdirs manually.
Will CC clean up the registry mess after me? Thanks for help.
What is the program?
Are you able to re-install it so that it will reinstall the missing unins000.dat ?
12 hours ago, hazelnut said:
		What is the program? COLD TURKEY BLOCKER
		Are you able to re-install it so that it will reinstall the missing unins000.dat ? NOT SO FAR
I have read that it is hard to uninstall. Have you tried contacting the makers?
You could try Geek Uninstaller Free and Revo Uninstaller Free, but without the unins000.dat file they may not be of any help.
		Are you able to re-install it so that it will reinstall the missing unins000.dat ? HAVE NOT TRIED YET
Was able to reinstall and missing file reappeared. Then able to do a normal UNinstall. Seems to be clean
2 minutes ago, CaptainP75 said:
Good news :)
Thanks for letting us know.
