Dear everyone,
When I use Drive Wiper, under Tools > Drive Wiper, to do a Free Space Only wipe on my C: drive it it start but only does 219.401MB for some reason. Even though my 500GB harddrive has 214GB of freespace. So I was wondering how I get it to whipe the entire free space?
Secondary issue that might be related. Right clicking on my C: drive gives me 251GB used 214GB available. However when I count all the files I have up by hand it hovers around 65GB. Lets give it some room for error and make it 100GB. Thats a pretty big margin of diffrence between 100GB used and 214GB used. So whats happening?
Additional information:
Windows XP SP3
AMD Athlon 64 FX-62
3,5GB RAM
500GB Western Digital HDD
defragged regularly
You can't wipe your system (C:) drive (it's in use). You need some bootable software/tool for that.
I am not doing a full wipe, just a free space one, no files are lost. In other words the I am trying to wipe the space where files use to be but are no longer.
Oh yeah true, my mistake. ![:D]()
Which CCleaner version?
Np ![:P]()
The version is v3.18.1707
Is it getting to 100%?
in other words are you seeing something like this (artist's render)
![post-21882-0-09344200-1337301318_thumb.png]()
How long does the wipe free space take? Are you sure it's 209.401 mb and not 209,401 mb?
I don't know how you counted 85 gb of files 'by hand', but there may be system or oter protected files you have missed, op sys, sys restore etc. I woldn't count up file sizes if you paid me.
(PS Please don't bump threads.)
Yes.
About 15 minutes
Heres a image of what is happening http://i.imgur.com/TZQH3.png
For some reason its no longer displaying the amount of MB it is whiping. I dont know why. It still finishes as usual.
OK, can you run Recuva to see what deleted files it can find after the wfs?
The image suggest to me that perhaps you are not wiping all of the free space but only the MFT which is a much smaller animal.
Indeed, but wipe MFT and wfs are not separable, are they?
Perhaps you cannot GET one without the other,
but you can SELECT only MFT on CC version 3.16.1666 (64-bit).
Under Tools => Drive Wiper I can select "Free Space Only" and "Simple Overwrite (1 pass) and I leave each Drive UN-checked.
Under Options => Settings I can check "Wipe MFT Free Space" independently of whether any Drives are selected for Wipe Free Space.
I refuse to predict or even test what Drive Wiper will do.
I only used it once and the only thing it got right was to wipe all the contents of a FAT32 partition.
Regrettably it chose the wrong device - I had selected a 2 GB Flash Drive and it took out a partition on my Internal HDD.
This is the answer, your OS is running in german therefore the Number format is a period between thousands not a comma.
In Brazil, Germany, Netherlands, Denmark, Italy, Portugal, Romania, Sweden, Slovenia, Greece and much of Europe: 1 234 567,89 or 1.234.567,89.
Thus your free space which is relatively 200 GB is being cleaned, I hope you have not continually be rewiping as this WILL end up bringing the life of you drive to a shorter time period.
