Which memory module is better?
I'm getting new memory, 4b, and I found two kinds from the same company OCZ. The first has a timing of 5-4-4-15, and the second has 5-4-4-18, both with a CAS of 5. Other than that, they are identical. Which is better?
http://www.hardwaresecrets.com/article/26
Can you link me to which modules you're looking at? Just so I get an idea.
Thanks
AJ
You can use the memory device which one is supported by your system.You should check both of them and choose the compatible one.
