Where does CCLeaner get it's OneDrive Versions from
Ok OneDrive is a constant software updater find. It always seems to find a version not posted on OneDrive Sync release notes - SharePoint in Microsoft 365 | Microsoft Learn
For instance, I just was offered (and took) an update of OneDrive from CCleaner. It was version 26.084.0504.0004
However the MS learn linked above has the following information
With no .084 listed anywhere.
@Laurence_CCleaner we’ve fielded many questions about this program and even this version of OneDrive, however we’ve never really had an answer. I remember in the past someone/company was offering ccleaner inside ring/Not-for-release versions and not actual releases, this angered the piriform people, now is their own product doing it?
Hi @Nergal,
Please could you use the support tool to send me log files so the dev team can review what is happening on the apps side.
The CCleaner v7.8 update will have some small changes to Software Updater, so this issue may be resolved in that update; however, it would be good to check with the dev team.
If you have any questions, please let me know.
Reply = “Send us a logfile” :rofl:
Did you really expect to get any actual straightfforward answer to what was a straightforward question?
I updated it, so I can’t do that, as soon as it comes with a new one
New OneDrive in CCLeaner
Latest as of today based on Microsoft
Support tool wants a ticket number and I’m not sure what you want me to do with it. (install the one drive? rescan for programs? what?)
I’ll leave this update alone for now. But @Laurence_CCleaner needs to give me detailed information he wants in the support tool’s discription etc
My current version which is higher than the official page due to a ccleaner update
Thanks @Nergal you can just put 12345678 in the ticket number and all you need to do is run a scan, so the log collector will get these scan results.
If you have any questions, please message me back :slight_smile:
ATUL2
The Following is AI Generated however it is Copilot and answering an easy search question (which i’ve found it fairly capable)
what is the Microsoft OneDrive version 26.84..0504.x branch (Stable, Release canidate, Experimental, etc)
Short answer: Based on all currently available public information, there is no officially documented Microsoft OneDrive branch labeled “26.84.0504.x”, and Microsoft has not published any release notes, ring assignments, or deployment classifications (Production, Deferred, Insider, Preview, Experimental, etc.) for a build in that numbering range. The build does not appear in Microsoft’s official OneDrive Sync release notes or the Microsoft Update Catalog as of May 27 2026.
Because Microsoft’s OneDrive versioning is tightly tied to ring-based deployment, the absence of this branch in official channels strongly suggests one of the following:
:bullseye: What the 26.84.0504.x branch most likely is
These are the only plausible interpretations given Microsoft’s documented release patterns:
1. An internal or pre‑production engineering branch
Microsoft frequently compiles internal OneDrive builds with higher version numbers than public rings. These builds:
  • Do not appear in the Production or Deferred rings
  • Do not appear in Insider or Preview documentation
  • Are used for internal validation, A/B experiments, or OEM preload images
  • Sometimes leak onto devices via OEM images or enterprise deployment tools
This is the most likely explanation.
2. A staged or throttled rollout build not yet documented
Microsoft’s release notes explicitly state that:
“New versions roll out gradually, so if your version number is higher than the versions listed here, your device is running a newer build that this page doesn’t yet reflect.”
This means a build can exist in the wild before Microsoft updates the documentation.
3. A specialized enterprise/GCC/GCC‑High/DoD ring build
Some OneDrive builds are published only to:
  • GCC
  • GCC‑High
  • DoD
  • Enterprise validation rings
These builds often never appear in public release notes.
4. A misreported or OEM-modified version string
Some OEM preload images (Dell, Lenovo, HP) ship with:
  • Modified OneDrive client builds
  • Pre-release sync engines
  • Version strings that don’t match Microsoft’s public numbering
:pushpin: What we can confirm from official sources
From Microsoft’s official OneDrive Sync release notes (May 2026):
  • Production ring is at 26.070.0414.0001
  • Deferred ring is at 25.224.1116.0003
There is no mention of any 26.08x or 26.84.x branch.
The Microsoft Update Catalog also contains no entries matching 26.84.* builds.
:brain: Interpretation: What branch type is 26.84.0504.x?
Given all available evidence:
→ It is not Stable (Production)
Stable is documented and currently at 26.070.x.
→ It is not Deferred
Deferred is far behind (25.224.x).
→ It is not a public Insider/Preview ring
Microsoft does not publish OneDrive Insider builds the way it does Windows.
→ Most likely classification:
:star: Internal / Experimental / Pre‑production engineering branch
This aligns with:
  • Higher-than-public version numbering
  • Absence from release notes
  • Absence from Update Catalog
  • Microsoft’s known practice of testing ahead-of-ring builds internally
Thanks for the log files @Nergal, I have passed these and the Copilot answer on to the team investigating this issue.
Sooooo, i’m going to eat some crow. While it was not a published at the time OneDrive and I’m still curious about how they get it (in this case early) but as of today the “Rolling Out” version on the learn site is indeed a 26.084.x branch as ccleaner was offering,
While i would like to know how they’re getting such far off as to be unreported versions I can consider this cleared up @Laurence_CCleaner
Thanks for flagging the highlighted version is now in the production ring.
The development team is investigating why this version was offered while still in the preview ring.
Once I have some more details, I will follow up on this thread.
To Note CCleaner finds a newer version than the .84 but I think they’re (for whatever reason) taking it from either Dev (likely) or Canary branch (figure that because my Experimental (beta) is lower version) However OneDrive is deeply integrated in Windows and may cause problems if a incompatible is triggered.
Hi Both,
I now have a response from the development team, so I wanted to follow up as promised.
CCleaner is not offering beta or preview builds of OneDrive.
The versions surfaced by Software Updater come directly from Microsoft’s official production update feeds. The reason a version can appear in CCleaner before it shows up on Microsoft’s public release notes page is simply that Microsoft pushes new builds to their production feeds before they update their documentation.
This is actually confirmed by what you observed yourself — the 26.084.x branch that CCleaner offered you eventually did appear on the Microsoft Learn release notes page, just a few weeks later. That’s exactly the pattern our team is describing.
As a current example of this behaviour: our data already shows version 26.088.0510.0004 present in Microsoft’s production feeds, but it has not yet been published on the Microsoft OneDrive Sync release notes page.
So to directly answer the original question — CCleaner isn’t pulling from Dev, Canary, or any insider ring. It’s reading from the same production infrastructure Microsoft uses to distribute updates; it just sees those builds slightly earlier than the public-facing release notes reflect.
