Yep, I forgot about that one. It's so small, and once installed, you barely know it's there.
Add SpywareBLASTER. Small, but useful
Forgot all about that too, and I do have it installed.
I loved spywareblaster but there didn't seem to be much point anymore with Opera being my default.
So it's gone to that great recycle bin in the sky, (where all the good apps go)
Yeah but SpywareBlaster will still protect you even if you don't use IE since so many programs rely upon IE's core components to update themselves, probably malware too like getting some spyware on your system unknowingly.
Agree 100% with Andavari, and it doesn't do any harm to keep SpywareBlaster on your computer. It only takes a few megabytes of hard drive space and doesn't use any memory.
On my WinXP machine I run Avira AntiVir, Outpost Firewall, SpywareBlaster, and MVPS and hpHosts hosts files. Then I do monthly scans with MBAM.
However, I use my Win2000 machine quite often and only run Sygate Firewall and MVPS and hpHosts hosts files. I use Opera exclusively on that computer, so I don't have SpywareBlaster installed (although I might install it considering the comments above). I also do monthly scans with MBAM.
I've never got ANY viruses or spyware on EITHER computer, despite having no active virus protection on the Win2000 machine (both are also behind my router's hardware firewall which gets a 100% on the GRC port test).
I use and like SpywareBlaster too. Did'ja know that the protection against "Red Sheriff" can get turned off without your knowledge?
Your friend had more the enough and maybe that's even why you went to help him. All those stuff sometimes conflict slowing the computer.they might even view a system file as malicious!! Ok your working environ matters and what you do.......downloading, surfing, emailing, are all different and we all know what each bring along. A good Antivirus and a SpywareBlaster will do!!! I have been fine with Kaspersky(workstation) antivirus wirh SpywareBlaster!!
Spybot-S&D mucking (not the word I really wanted to use) with SpywareBlaster is why I removed Spybot-S&D. Spybot-S&D messed with it for a long time disabling some protection.
I freaking love my Avira Premium Security Suite.
I protects me from everything, from anywhere.
And the high heuristics catch the unknown stuff.
+ I use Returnil.
Avast, Malwarebytes and windows firewall for me.
these gives me a level of peaceful.
I agree that user is the best protection.
Now I just switched to NOD32 4, and I'm loving it!
can nod32protects you from ads and banners?
No, NOD32 is just another AV, and it's the best one out there. (I take my comment about Avira back). If you want to block ad's and banners use Adblock Plus if you use FF, if you use Opera use Fanboy's adblock list, and if you use Chrome, or any browser based off of it, use Adsweep (which has been discontinued).
ok and talking about protection,did you guys take the firewall test by shields up.. or pc flank
....specially the pc flankleaktest and the leaktest by shields up
I think you should take both of the tests, just in case.
did you take them?...
Yes, I did.
We've drifted so far from the original topic
well this is about protection..
