I just cant seem to get my head round why some people run so much protection.
Just earlier i went to help my friend with his pc and he had, malware bytes, adaware se, zone alarm, nod32 & winpatrol all running at once.
I have nothing running, only xp built in firewall. Common sense with firefox(no script and netcraft add-ons) and i have not had an infection in 3 years.
I do monthly scans and always fine. My computer runs perfectly.
so come on people, why do you choose to run so much
I guess it's because computers are a bit like cars for some people, they're personal
What works for you may not suit others.
Yes, you can have too much and I think that is all part of the learning process, gradually people seem to trim down as their experience grows. However just xp firewall and firefox is a bit thin on the ground in my opinion. But that's just my opinion.
After all, it's your computer
Hello, sorry i hope i didnt sound a bit.... dont know what the word is i'm looking for but hopefully i didn't seem to negative.
I was just simply curious.
I know it seems thin, If i was ever sus of any thing i would check it out in a virtual machine first.
But like you said, each to there own.
i think people just like the feel of they r in control.
Noting worse then being in the middle of a game and 'virus data base has been updated' comes up
I don't have games on my PC, but I agree with your point. I have Avast set to inform when there's an update, in case I'm in the middle of something like a music or video file conversion.
That being the case I ignore it, and it's never too long before it pops back up, or I immediately update manually when the conversion is completed.
I've found out the hard way that conversions can be easily screwed up by something else going on during the process.
Automatic updates with Avast are always silent, but you can set it as an option with manual updates, which means once you set it away, you won't get the popup progress windows.
I find it easier to use the popup windows so I know when it's finished doing it's thing.
...so come on people, why do you choose to run so much
For a long time it was because I was not sure the products would do what they said. And sometimes they didn't. Sometimes they still don't.
I got hit very early on with coolwebsearch, good grief, what a nightmare. Nobody had removal tools, you just chipped away at it until you got it out or reformatted.
Nowadays I think that virtualization is the way to go, and then run a lightweight free antivirus and maybe an antispyware app. If the virtualization app works, then it will save you if all else fails.
Besides my anti-virus and anti-spyware programs running, I like to run WinPatrol and ZoneAlarm. Not only do they provide extra protection - which some may argue is not needed - but I like to know if anything is trying to put itself on the starting list etc. and also what is trying to reach the internet when it has not had previous permission to do so.
In other words...for me personally, I like to keep an eye on what is going on in the land of XP.
Multi-layered protection isn't a bad thing so long as too much isn't resident at once since that would create a bottleneck in system performance.
The only protection I have running resident all the time is Avast and nothing else simply because I don't need anything else running. All I use now which was recently trimmed down is just Avast, MBAM, Windows Firewall, and my DSL modems hardware firewall. I simply don't need excess to have a clean system, although I do malware scan any and all downloaded files even those from trusted sources.
Actually the only thing that could possibly get in is something I'd have to manually download like this episode which taught me to unpack everything first before initiating any installers.
I am using Ubuntu, a version of Linux because there are no virusses for linux and Linux is the safest OS out there.
Here's why: There is a package manager in every version of linux. in that package mamager you will find all software for linux that has been checked for virusses and so installing from there ensures the software is OK. Installing programs there is as simple as just one click, and the computer does it all for you. Now when you download software from the internet, which you sometimes need, there is a security feature: you have to go to the file's properties and set the file to executable mode if you want toexecute it. Also the linux user management is very good: the admin can choose the rights for every single user. Also, to install stuff you have to be the user root (administrator). as a security feature you can't log in as user root, you can only start single progams as root. This concept has been introduced to vista but it has been used for years now in linux. Also the vista aero interface has been copied from linux: linux is fully customizable and there are plenty themes availabe (gnome-look.org). Vista is copied from one of those themes, but i don't remember from which one exactly.
...100,000 computers infected. If you multiply this by 90 (because Linux has ~1% market share and Windows has ~90%)...this becomes 9 millions...Conficker, anyone ?
I only use Avast and the Windows firewall. Never had a virus. People using lots of anti-malware, anti-virus, anti-something, anti-somethingelse, etc., are paranoid
I've got Avira which has AV and AS and it's also the best AV out there. Also Windows Firewall. Like Ishan said, I also check with MBAB about 1-2 times a month. Also use common sense.
This is pretty much spot on to me. I do have avast on my pc. And i do occasioanl use it, i did use to always run it. But i dont feel the need any more.
Thanks for answering people, i was very curious to why some people run 4+ applications for protection. I know there is nothing wrong with it, I just think there is to much paranoia out there
You really do need to supplement Avast with something like MBAM or SUPERAntiSpyware (either free or paid versions), as there's some stuff Avast just doesn't detect.
