What means a "*" after a custom clean entry?
Behind some of the entries in "Custom clean" section there is a "*"
What does that mean?
33 minutes ago, thoste said:
Note: An asterisk (*) next to an application's name means that you (or a system administrator) have added it to CCleaner as a custom application.
https://support.piriform.com/hc/en-us/articles/360047824692-Applications-tab-for-CCleaner-for-Windows#apps-and-files-you-can-clean-with-the-applications-tab--0-6
You will see them if you have used "winapp2.ini" to add extra custom cleaning rules to CCleaner.
Anything added to the cleaning list by winapp2 will have an asterisk following the name.
