it deletes the thumbcache_????.db files where ???? will vary depending on the thumbnail cache in question.
if you aren't seeing any to clean, maybe you either have Always show icons, never thumbnails in Windows Explorer, or you aren't doing whatever generates them.
Thumbnail Cache - This option clears the Windows Explorer image thumbnail cache, which is maintained to speed up the browsing of folders containing photos and images. But it will also contain the thumbnails of images that are no longer on the system. (This rule is for Window Vista only.)
but i don't know if it's related to older version of ccleaner
Mta did you test it ? i mean does it delete thumbcache located here C:\Users\%username%\AppData\Local\Microsoft\Windows\Explorer
i'm running ccleaner last version under w8.1 64 and w7 sp1 64
