Weird crashes when cleaning
CrapCleaner hs been working fine for a long time but in the last few days (and with the last version) when cleaning the PC it sits there for a moment and then crashes. I removed and reinstalled it a few times which makes no difference. The eventviewer does not show any reason for this either.
Is there any logfile or suchlike somewhere which I could consult?
thanks!
Dries
What security software do you use? (eg Kaspersky, Malwarebytes)
Also see here
https://forum.piriform.com/topic/52058-ccleaner-v543-close-on-clean-work-around/
I am using Kasperski but have been doing so for quite some time. Besides, it is not during registry cleaning that it crashes. Registry cleaning works fine, it is regular cleaning that fails.
thanks!
Have you tried the fix in the link I posted?
Yep, tried it and it solved it, thanks!!!
