weird caps lock/num lock/scroll lock notification bar
About 2 days ago, if that, there was a little bar that was popping up if I had Caps lock or other locks enabled or disabled. I have no idea why its doing that, I didnt change any setting. The only thing I can think of is I installed a bluetooth adapter, and thats it. It looks more like a system notification, and not from a program, if that helps. Screenshot if you need one (my connection was weird, so I didnt have patience for it right now). How do I end this stupid message bar?
Have you had a quick look in your keyboard settings in the control panel?
What you installed may have just interferred with something there.
Only other place I can think of to look at the moment is in control panel accessability settings which allows you to have a beep etc if you do caps lock or a flsh up on the screen. However I don't think this shows as a bar in the notification area.
I looked at keyboard settings, but there are no options about that. I haven't seen any option that would do that, so I'm still a bit confused...
