Web images broken
I ran CC for the first time and now most web page images are broken, won't load.
I use Netscape 7.0. Do you know of a fix? The images do load if I use IE.
Thanks!
If you have Netscape running and then ran CCleaner that could be the problem, however I can't be totally certain as I don't use Netscape and don't know if it's based on Firefox or SeaMonkey.
In the future make sure you exit Netscape first before running the CCleaner. With Netscape closed you could run CCleaner a couple of times to see if that fixes it. However if that doesn't work run the cleaning tools that are built into Netscape, then exit Netscape, restart it, and see if images work.
This used to be a problem with Firefox until CCleaner started to warn of Firefox running.
P.S.
Welcome to the CCleaner Forums sgupson! :)
That worked. I did have Netscape opened the first time so I could read the help guide
while I explored and ran the product.
Thanks for your help and time!
You're welcome!
The beginner's guide is also available for download so that you can have a local copy as BeginnersGuide.zip located in the middle of the first post in this thread:
http://forum.ccleaner.com/index.php?showtopic=1504
