We really need junk file removal.
I recently download a app called DustBuster and i first ran cclceaner then ran dustbuster and dustbuster still removed over 600Mb of junk. Now as we are getting close to version 2 i thought it would be great for CCleaner to scan your pc for selected junk files and the ability to add your own junk file extensions. Here's hoping :D
"DustBuster is a garbage file removing utility for Microsoft Windows operating systems. It searches for junk files and temp files that are of no use and are just taking space on your hard drive. Based on a "common sense" scanning technology, DustBuster now cleans over 1500 different types of useless temp files and directories in a single click, detecting and deleting all these unneeded files automatically."
Link to official site: http://www.casperize.com/dustbuster/dust_en.htm
I tried it and didn't like it because you see absolutely nothing that is being deleted. It just goes through and deletes. They need to fix it a lot before I'd use it like CCleaner.
That's what im saying tho i would prefer if CCleaner was able to scan your pc and remove file with selected file extensions and maybe have a forum section where as people discover more file types that are junk they can post the dot extension.
*.bak and *.gid are generally safe to go.
I so agree with the posts above ... doesnt show what its deleting :)
