Been researching the cleaning of XP Pro and most "experts" say the best and most effective time is soon after a re-boot.I tried the / Auto command which works fine after (eg) browsing, but at sys. start up, it seems to be trying to clean at the same time as my AV/Firewall etc etc are starting/loading, therefore I would like to add a delay of 60 secs( or longer) so after my coffee is poured, I can sit down to a ready-to-go-PC that has also been crapcleaned. Is there an easy way please?
I use this program for delaying some programs at startup: http://www.r2.com.au/software.php?page=2&show=startdelay
Thanks for that CeeCee, but I really prefer to just add a command rather than install a special application. ( By the way a year ago I tried that app and did extensive tests--in the end it SLOWED down my startup, that was the net effect!) Thanks anyway.
Overview: Use XP Task Scheduler to execute a script
Open notepad and copy and paste the text below into it... Look at the path below to CCleaner and make sure its correct for your system.
Option Explicit
DIM Wsh
Deleted by Disk4mat
