Voglio il rimborso dei soldi e annullamento del rinnovo automatico
Voglio il rimborso dei soldi e annullamento del rinnovo ho acquistato un mese fa la versione di prova di ccleaner e ora si sono presi i soldi del rinnovo l’email è {Removed by Mod} rimborsate i i soldi e annullamento del rinnovo automatico
If you want to manage and/or cancel your subscription then there is a webpage for that here: Subscription Management
If you can’t use those, (eg can no longer access your registered email), or for anything else account/billing related, including refunds, then you will need to contact support.
All customers MUST now use the ‘Live Chat’ support service. It is currently the only way to contact support.
To start- fill in this form: Contact Form.
Below that is the button to go into the ‘Live Chat’ where a virtual assistant will try to help you initially based on what you have put in the form.
IMPORTANT- Don’t just fill in the form and leave - If you do not engage with the chat then you will not get any reply.
