I suspect ccleaner have deleted the wrong entries in my register.
Since I used version 2.17.853 the debug mode malfunctioning and it's impossible to reinstall it.
Microsoft VB6 setup show a message with a problem on the updated components when he finish the installation.
Can you make a VB ERASER ?
(I'd like to install it properly)
Welcome Duke49
What operating system do you use?
What is a VB ERASER?
Windows Vista SP1 32bits
AMD Athlon X2 DC 4200+
2 Go DDR
VB ERASER ![:)]()
A tool to completely erase the traces of VB6.
Welcome to Piriform Duke.
VB ERASER
And why would you want to do that? ![;)]()
Hello ![:rolleyes:]()
because i cannot reinstall VB and no one could help me.
After installing the files in the setup, it crashes when updating components.
Causing the problem in debug mode step by step, I cannot move my yellow cursor with the left mouse button, it do only breakpoint.
So i had uninstall and now im blocked !
VB ERASER
Are you referring to the installation of Microsoft Visual Basic Runtime v6.0 SP6? The Microsoft website doesn't list Vista as a supported operating system!
Note that you can unpack the setup file with any archiving software than can decompress/unpack SFX CAB archives to check the file versions.
Something I saved into a readme file with the setup file:
Before you install you can check the already installed Run-Time by using the chartbelow that lists the version number, and date of the files that will be registered.Only files registered into the Windows registry by the installation are listed,there are however more files installed.FILENAME: | VERSION: | SIZE: | DATE:----------------------------------------------------------------------------------comcat.dll | 4.71.1460.1 | 21.7 KB (22,288 bytes) | May 08, 2002----------------------------------------------------------------------------------msvbvm60.dll | 6.0.97.82 | 1.32 MB (1,386,496 bytes) | February 23, 2004----------------------------------------------------------------------------------oleaut32.dll | 2.40.4275.1 | 584 KB (598,288 bytes) | April 12, 2000----------------------------------------------------------------------------------olepro32.dll | 5.0.4275.1 | 160 KB (164,112 bytes) | May 08, 2002----------------------------------------------------------------------------------
Well Andavari I've run VB apps of Vista without installing anything and they work perfectly. I've never tried to install VB6 of Vista but I know some people have problems.
Duke have a search on here to see if other users have a similar problem.
Another link about VB on Vista on VBForums and here.
The basis RunTime Files are already installed on Win2k/XP/Vista. It sounds like Duke is having a problem installing VB initially. I presume Duke that you are trying to install VB as an Admin?
You can unpack anything from Microsoft with WinZip just right-click on the file and select Open with WinZip. ![;)]()
Problems installing Visual Studio 6.0 on Vista Ultimate
Support Statement for Visual Basic 6.0 on Windows Vista
It's certainly not Microsoft Visual Basic Runtime v6.0 SP6 because Duke49 said "VB ERASER" (ERASER). By the way, Duke are you sure it's VB Eraser?
