Vista zip Info & Help
http://support.microsoft.com/search/defaul...ode=r&lsc=0
The Help and Support feature stops working when Dreamweaver is configured as the default XML editor on a Windows Vista-based computer
(937491) - Fixes a problem that occurs when you try to start Windows Vista Help. ... To download the registry fix as a compressed (.zip) file, visit ... Right-click DW8_Fix_Help_and_Support.zip , and then click Extract All . ... information about other Windows Vista-related issues, see the "Vista help system stops ...
http://support.microsoft.com/kb/937491/en-us
http://support.microsoft.com/kb/308090/en-us
This article was previously published under Q308090
SYMPTOMS
When you download a Zip (.zip) file in Microsoft Internet Explorer, you may experience either of the following behaviors:
? The file appears to download, but the file compression program that you use (for example, WinZip) opens and displays a blank window.
When you search for the file, you are unable to locate it. The file does not exist on your hard disk.
-or-
? If you are running Microsoft Windows XP, and you use the Compressed (zipped) Folders feature as your file compression program, you receive the following error message:
The Compressed (zipped) Folder is invalid or corrupted.
http://support.microsoft.com/search/defaul...&spid=11732
http://news.softpedia.com/news/Zip-and-Unz...sta-43588.shtml
Zip and Unzip in Windows Vista- Remember XP? * [ PDF ] *
http://forums.microsoft.com/Communities/Sh...92&SiteID=6
http://www.ghacks.net/2007/11/01/windows-v...arge-zip-files/
Windows Vista has problems with large zip files
Posted by Martin in Knowledge, Operating Systems, Windows Tags: microsoft, vista freeze, windows-vista, zip
http://www.pcdoctor-guide.com/wordpress/?p=4595
How-To Geek also has a solution to the problem, which is basically to disable the built-in ZIP file handling in Vista
http://www.techlifeweb.com/2008/04/05/repl...in-zip-utility/ [ 7 Zip ]
http://itsvista.com/2007/01/itsvista-tip-1...es-and-folders/
I have the same problem - empty folders when trying to extract Zip files
http://www.jzip.com/
7-zip offers a state of the art compression engine. It's a good application and this is why we decided to use 7-Zip as our underlying compression engine.
3. Is jZip a new compression format?
No. jZip is not a new format. jZip supports known formats such as Zip, RAR, 7z, TAR and GZip and is compatible with other compression programs like WinZip, WinRar and 7-Zip.
http://www.pcworld.com/downloads/file/fid,...escription.html
Operating Systems: Windows XP, Windows Vista
http://www.majorgeeks.com/jZip_d5774.html
Size: 2.34 MB jZip 1.2
http://www.softpedia.com/progClean/jZip-Clean-82782.html
The new free jZip 1.3
* Create, open and extract Zip, TAR, GZip and 7-Zip. Open and extract from RAR and ISO.
* jZip is absolutely FREE for everybody, home and enterprise users
* jZip is an easy to use and fast archiving software
* jZip is based on proven 7-Zip technology by Igor Pavlov
jZip v1.4 beta ?
Note: This is not a final
release version, but it
includes more features
http://lifehacker.com/software/featured-wi...jzip-303245.php
http://en.wikipedia.org/wiki/ZIP_(file_format)
Results 1 - 10 of about 676,000 for Zip help Windows.
http://windowshelp.microsoft.com/Windows/e...cd341a1033.mspx
