Vhs to Avi?
I have got something like 200 Dvds and only a few videos mainly home movies and i want to get them on my pc so i can burn them anyone know how i can do this?
Englishmen, I do burn old videos to disc (for my own use of course, and I bought the videos!)
Basically I just plug in leads, the ones with the yellow,red and white ends.
First plug them into back of video player, audio out and video out.
Then into the computer. composite, audio in and video in.
Next you have to have some kind of software, I have Powerdvd.
Put in blank dvd. You choose PAL, because you will play it in the uk. Choose analog as the place you will record from. Front line in for sound.
Press play on video and then press record on your software.
Power dvd burns it straight to disc.
Nero ( which I now longer have ) is also able to do this but it goes to the hard drive first and you have to burn from there.
Hope this is of some help :)
