uTorrent temp torrent files cleaning
I would like to suggest for CCleaner to add the ability in the applications section for the cleaner, the cleaning of uTorrent temp files, located in (Windows 7 x64 installation):
%AppData%\uTorrent
or
C:\Users\******\AppData\Roaming\uTorrent
If torrents aren't removed by right clicking the torrent, and then selecting "Remove And" --> "Delete .torrent" then that folder can become full of torrent files.
Already discussed here, and it isn't safe to do.
I don't know why it is said the "it is not safe to do so", since the provided link to the explanation is gone by now, but I guess it is because μTorrent uses some of these files.
FYI, there is a solution out there that "removes" only the TORRENT files that are not used by μTorrent:
http://forum.utorrent.com/topic/40826-delete-unused-torrent-files-in-userprofilesapplicationdatautorrent/?do=findComment&comment=500969
It tries to work in a safe manner without affecting μTorrent, but still you have to take the risk of running an unsigned EXE downloaded from the web.
I hope this helps someone. The above link will provide more info.
Cheers! :)
After 4 years I reckon all involved have moved on or just plain forgotten about it...
