Utilities - What does CCleaner do to these?
I'm looking at the Utilities section and I'm wondering what CCleaner does to Spybot, for example.
I'm not so sure that Spybot is generating anything that CCleaner needs to touch.
Does anyone know what CCleaner does to these programs in the Utilities section? Is it cleaning up log files? What?
Thanks...
Thanks...
Yes, logs and statistics only. Opening winapp.ini in notepad you
can see which files/entries are to be deleted for each application.
