I am using Crap Cleaner for a long time. And it's helps me greatly.
There's one another ineresting tool for using at home and at office PC's.
This is how Rohos Welcome 1.20 works. Rather then entering one's logon name and password upon startup, a person simply inserts USB drive. The drive contains login and password information that is entered automatically. + automatic desktop locking upon USB Key removal.
Ladies and gentlemen we have genius in the house. But what the hell is the point in paying for something that will save you 3 seconds when logging in then save you from activating your screen saver to come on after 1 min? or clicking the log off button?
Nobody can log into your system without the USB key, even if they know a username or password. Look up "smart card" on howstuffworks.com or something. You should probably read the entire Rohos site before making yet more comments about saving 3 seconds.
Next up is biometrics, where you put your thumb on a reader to login.
Think of the USB as the key, and the computer as your house. You want to get in you have to use the key, otherwise no one can get in unless they forcefully break in.
Yes you. I did quote you after all. You've been acting weird.
Am I sorry about that, I'll tell you what I'm staying away from the post from now on, I do not not want any tension between I and anyone else over such a ridiculous subject.
P.S. Obviously do not post a reply to this message as i obviously will not read it
it look cool... but what if owner lost the key... is there anyway to login to windows again?
