Using unicodes?
Hello. Was just wondering on do you use unicodes? I know you can use alt+number but was having a read last night....
http://en.wikipedia.org/wiki/List_of_Unicode_characters
There are loads, and there are a few i would like to use. Example
Code Result Description
U+02B0 ʰ Modifier Letter Small H
How on earth do you use/type U+02B0???
I spent ages googling but come up with nothing
sam
Well as I understand it unicodes are used to convert characters. In VB you can't show Chinese, Japanese, Korean, Greek etc because they don't use alphanumeric characters you have to convert them. I'm not sure if CC uses unicows.dll for the same reason on its language convertor. I know it uses the dll's in the lang folder. ;)
Unicorns?
