Using Defraggler
I just installed defraggler but can't find out how to select fragmented files so as to avoid an entire defrag. I see that there are some files that could be defragged but how do you tell what they are?
Thanks
alan
After analyzing a drive there will be a list of fragmented files. You can just check the ones you want to defrag. You can right click a file and select "Open Containing Folder" to check what it is.
It's alright to check the files without knowing what they are. It should not mess up the system.
Well that's easy. Thanks so much. The only things showing after an analysis are the fragmented files, right?
alan
Right. If a file is defragged, it will say 1 fragment and will be removed from the list the next time you analyze.
