I've just used CCleaner to clean up my drives (mainly to get rid of index.dat files) but I can't understand the analysis. It says the following:
"(5.25MB to be removed)
Details of files to be deleted (Note: No files have been deleted yet)"
I keep running the cleaner but it always says the same thing, even when I have rebooted. I can't think of anything else to try.
Why does it keep telling me the files will be deleted, but without actually deleting them? I'm new to all this so apologies if it's something really simple I can't seem to grasp. It's a steep learning curve.
If they're index.dat files - marked for deletion - then they will not be deleted by CC but will be deleted by the O/S when you reboot your pc. Windows will immediately recreate empty index.data files again, so you will always see these files marked for deletion whenever you run CC. Do you have any other files apart from these?
