we recently tried to install this chessmaster software by ubisoft and it didn't work coz my dad missed one of the requirements which was for our video card....and now the uninstall of the program won't work and neither will add/remove program...is it safe for CCleaner to do it or what?...and good thing I checked this website first coz i really wanted to gain space by using the registry feature and you guys said it's for experts so I didn't mess with it...Please Help thank you
A thought-try using the XP System Restore. Go back a week or so before the attempt to load the program. See if that fixes things. Even if it does then do the following:
CCleaner will try to remove the program in question. You will also want to look for the program's folder and delete it. Not knowing your level as a user, I won't explain how to edit the Registry (it is an Expert function). The Registry cleaner has not done anything nasty to me in the years I have used CCleaner. Tread caefully-whatever you do.
Hello kensync,
Maybe this will help.
Just be sure you look in that folder and make sure you don't have any other games in there.
I am not an Expert,yet.You can become an Expert also.Read and learn.Make some mistakes.
Read and learn how to correct your mistakes.Don't make those mistakes again.All of a sudden
everybody is calling you an EXPERT!!!
I am sure it works the same for other versions.
Good luck,
davey
If you are not sure what to do,just come back for more help.OK!!!
Are you planning to play against your Dad or the computer?
Give him a big hug for trying.
Hi kensync, and welcome to the forum.
Once you have that sorted, here's a nice little chess program (free), which once downloaded, runs from a simple exe file. In other words it doesn't "install" fully into your operating system. Easy to get rid of, but still a cracking little program.
Comes with a comprehensive on-line help file. (Double click the help.htm file in the downloaded folder).
To run program, just double click the slow.exe file in the same folder.
Hello kensync,Maybe this will help.
Good luck,
davey
thanks but i don't want to make a mistake that will result in me having to reformat my pc...coz i know registry is where all those dll stuff are....and the file deletion thing seems like it would leave some errors...it's just that I have a lot of files and i can't risk having to reformat...thanks for the help though...if you can still help that'd be great =)
If the info Davey gave in the screenshot is correct you can do no harm just deleting the Chessmaster folder in Program Files (the only harm you'll do is to that chess program itself which, as were trying to get rid of it, is exactly the intention)
