Hello, I direct all support personnel to THIS link: http://social.technet.microsoft.com/Forums/en-US/w7itprogeneral/thread/e286be80-ed7e-4026-b6b7-d512ff642db5/'
There is a critical remark/discussion about certain event-errors in windows being logged/generated as a result of a recent piriform update, if you check the Application tab "SEARCH" box for cleaning. I am having the EXACT same problems described in this link, and I will see if this still occurs after unchecking meanwhile I invite Piriform support to investigate this issue thoroughly.
MORE: 1811 errors being generated:
Windows (3084) Windows: Error -1811 occurred while opening logfile
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\MSS00032.log.
** Windows does NOT like you deleting these logs! They seem to cause a cascade of other errors!!!
Urgent? It's been hanging around since Sept 2011. According to the response from a MS staff member in that thread the cause is a problem with Windows Indexing. Unchecking the Search box in CC may stop the errors, but is the underlying problem with Win Index? (I can't test as I don't have a Search box in Applications, presumably as I have disabled Indexing, or I'm not on Win7, or both.
Later edit: Aha! Nergal adds some sense.
I assume the poster speaks on this Rule
[MS Search]
ID=2266
LangSecRef=3025
DetectFile=%CommonAppData%\Microsoft\Search
Default=True
FileKey1=%CommonAppData%\Microsoft\Search|*.log|RECURSE
I kinda agree that this may be causing some issues. I believe there may have even been a topic on this in the recent past
http://forum.piriform.com/index.php?showtopic=34861
I find it remarkable that deleting a log file can cause Win7 such issues. ![:huh:]()
