Update installer (CCleaner pro plus)does not download
Recent upgrade installer does not download. Retried x6. No progress after an hour. Noted installer labelled 32 bit, (on Task Manager) but my current Cleaner is 64 bit.
is it the download or the install that isn't working?
get your download from here; https://www.piriform.com/ccleaner/builds
it's the free version but once you plug in your license key, it'll be the Pro version.
as to the installation, make sure you haven't got CC already running, like monitoring for example.
and the installer probably is only 32bit, no point having a 64bit installer that only gets run once right? :)
once installed, there will be a 32bit and a 64bit version of the software.
when CC starts, it'll detect the bit-ness of your OS and run the appropriate version.
Thanks! All well with that download link. CCleaner working fine. Problem may have been due to an influx of 8 updates from Microsoft, and 3 from iTunes!
excellent news.
thanks for letting us know.
