Unsigned kernel module
Whenever I launch Speccy Windows complains about loaded unsigned kernel module.
The Warning appears in Event Viewer: Applications and Services Logs→Microsoft→Windows→CodeIntegrity
EventID:3001
Code Integrity determined an unsigned kernel module \Device\HarddiskVolume1\Users\UserName\AppData\Local\Temp\... is loaded into the system. Check with the publisher to see if a signed version of the kernel module is available.
"..." refers to long string of letters and numbers that is different each time Speccy is launched. With the help of Sysinternals Process Explorer I could identify that the module referenced in the event 3001 is C:\Users\UserName\AppData\Local\Temp\speccycpuid.dll
P.S. I changed my real account name to UserName in the paths.
What operating system are you running?
