I get "Unknown system error: 0x80041002" under all sections
What version of windows do you use?
Has it been modified in any was or was it just a standard install?
Windows XP, I replaced my video card and PSU, before that it worked fine
Same problem here.
XP, no replacements or modifications, Speccy never worked. This is an assembled PC though.
Run Event Viewer (eventvwr.exe) do you have any entries that relate to this error code??
Richard S.
I don't actually know because I never look at the Event Viewer, but I assume it records error popup windows, otherwise I don't see anything related anyway. This error, "Unknown system error: 0x80041002", is not a popup error. It's just the text shown under all sections, previously said. Where the technical information for each thing should be shown in the program
Noone has a solution for this problem? I also would like to know how to solve it.
in nmy case eventviewer says:
type of happening: error
source of happening: Application Error
category of happening: none
identification label: 1000
Date: 24.08.2010
Time: 09:06:12
User: N/A
Computer: xxxxxx (not of ur bussines ;) )
Beschreibung:
failed application speccy.exe, Version 1.4.0.173, failed Modul speccy.exe, Version 1.4.0.173, error address 0x000e25ce.
further Informationen about the help- and support service may retreived at http://go.microsoft.com/fwlink/events.asp (dats what microsoft says......).
Dates:
0000: 41 70 70 6c 69 63 61 74 Applicat
0008: 69 6f 6e 20 46 61 69 6c ion Fail
0010: 75 72 65 20 20 73 70 65 ure spe
0018: 63 63 79 2e 65 78 65 20 ccy.exe
0020: 31 2e 34 2e 30 2e 31 37 1.4.0.17
0028: 33 20 69 6e 20 73 70 65 3 in spe
0030: 63 63 79 2e 65 78 65 20 ccy.exe
0038: 31 2e 34 2e 30 2e 31 37 1.4.0.17
0040: 33 20 61 74 20 6f 66 66 3 at off
0048: 73 65 74 20 30 30 30 65 set 000e
0050: 32 35 63 65 0d 0a 25ce..
annotation: translated from german to english by some1 who's not a perfect english speaker. so there may be some deviations from original titles.
im getting the same error, but im running win 8.1, and eventvwr.exe gives me this message relating to this error code
Windows Management Instrumentation ADAP failed to connect to namespace \\.\root\cimv2 with the following error 0x80041002
what am i to do about this?
Error 0x80041002 is often an indication of a corrupt WMI repository.
Speccy reads the WMI to collect data to display.
Try the Microsoft hotfix:
https://support.microsoft.com/en-us/kb/2465990
PS. this thread was 6 years old, it might have been better to start a new one.
