Unknown information in Scheduler section of Operating System
Hi,
I was looking at the Scheduler section in the Operating System protion of Speccy and there's some unusual information that I don't recognize. It shows relevant info on stuff I have scheduled updates for, like windows update, spyware, and anti virus, but this one I don't recognize and it just started on 02/26/2013 of this year.
This is a protion of what it says, there is no name and there are additional numbers after these. The schedule says its stated to update every 4 hours. I don't remember installing any new software on my computer or setting a schedule around the date listed. Does anyone know what this might be? Thanks, Mike
update-S-1-5-21-1566824163-3711447830
Recycle Bin. Defraggler showed a similar named path item as my fragged bin. It wasn't listed in Speccy. (Win7)
Can you find that item in your System Task Scheduler? . . Start\ Admin Tools\ Task Scheduler\ Task Scheduler Library
Are you on Win8?
??? what is a portion? did you post a screenshot that i can't see?
that's just your computers name for a Proper-Username account. EXAMPLE: if your computer knows you as mike, then mike=S-1-5-21-1566824163-3711447830.
so i've (windows8) two tasks with that type of code. One is for my user while another is for the stupid NVidia "updateuser"
Thanks for the enlightenment. :) My search results ►
C:\ProgramData\Microsoft\Crypto\RSA\S-1-5-18
C:\Windows\System32\Microsoft\Protect\S-1-5-18
C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Crypto\RSA\S-1-5-19
C:\Windows\System32\Microsoft\Protect\S-1-5-19
C:\$RECYCLE.BIN\S-1-5-20
C:\Windows\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Crypto\RSA\S-1-5-20
C:\Windows\System32\Microsoft\Protect\S-1-5-20
C:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
C:\Users\student\AppData\Roaming\Microsoft\Crypto\RSA\S-1-5-21-2944540795-3523994118-1725021127-1000
C:\Users\student\AppData\Roaming\Microsoft\Protect\S-1-5-21-2944540795-3523994118-1725021127-1000
D:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
K:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
L:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
M:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
S:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-1000
D:\$RECYCLE.BIN\S-1-5-21-2944540795-3523994118-1725021127-500
C:\Windows\Prefetch\AgCx_S1_S-1-5-21-2944540795-3523994118-1725021127-1000.snp.db
C:\Windows\Prefetch\AgGlUAD_P_S-1-5-21-2944540795-3523994118-1725021127-1000.db
C:\Windows\Prefetch\AgGlUAD_S-1-5-21-2944540795-3523994118-1725021127-1000.db
C:\Windows\ServiceProfiles\LocalService\AppData\Local\FontCache-S-1-5-21-2944540795-3523994118-1725021127-1000-12288.dat
C:\Windows\System32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2944540795-3523994118-1725021127-1000_UserData.bin
C:\Windows\System32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-3111613574-2524581245-2586426736-500_UserData.bin
C:\Windows\System32\wdi\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-4109802697-684869941-3642691011-500_UserData.bin
C:\Windows\System32\Tasks\WPD\SqmUpload_S-1-5-21-2944540795-3523994118-1725021127-1000
