First, I like ccleaner after using cleanmaster, no bloat!
However, one nice thing about cleanmaster, when installing apps, it would also search out anything left behind. For example, Dolphin would also install another program (app) and cleanmaster would ask if that should go too. And, SDMaid Pro also does this (it's called corpse finder).
So, my question is, does ccleaner also search out these left behind apps?
If not, it should be included in future versions, IMO.
CCleaner uses the exact same uninstaller that Windows Add/Remove uses. So no it won't search for leftovers like Revo Uninstaller will and the tool you mentioned.
Sorry for the lack of replies, the forum has yet to have much traffic from Android CCleaner users, so many of us here don't have an answer for you; however, since he has not yet said anything, I will attempt to apologize as @Andavari's proxy and say that he misread and answered for the windows version and not the android one. If you have some patience, hopefully a user will come by and answer.
