Uninstall features.
Hey so CCleaner does not appear in uninstall tabs in windows settings and control panel.image.png.4b7e75cfac81049113d262a60b683b66.pngimage.png.432a457c4ba0ac52e53023538570928e.png
Have you successfuly installed CCleaner?
It should show as an installed app if you have installed it. Usually just above Cortana.
(The portable version won't show of course because that is not installed).
Is it showing in CCleaner's own uninstall tool?
