Unexpected Error while Registry Cleaning
Hi
since the last 4 Versions (or so) i get this Error everytime i start registry cleaner:
AtlThrow: hr = 0x80070057
CCleaner v4.00.4064
MS Windows XP Professional SP3
Intel Core2 Quad CPU Q6600 @ 2.40GHz
3,0GB RAM
NVIDIA GeForce 7300 LE
ID=-1
PR=3702
DA=
RK=HKCR\
RU=2
CK=-2147483648
SK=
VK=
VA=
CR=2
PF=0
EI=0
FL=0
IIT=0
FI=-1
SI=0
whats going on?
Comodo firewall (deactivated)
Avira free Antivir( deactivated)
please help
thx
Merge your last registry backup before you had the issue.
i don't have any backups. the history is empty...
Do you have a Restore Point you made before the issue?
No, i don't. never made one...
This is a recurring issue for which I have no immediate fix. We'll wait for help from another member. :)
