All right. I'm not sure that this is a problem with the Recuva program itself, or simply my computer. Whenever I try to scan my C: drive for deleted files, it never works. I've uninstalled and re-installed the program twice, and I've tried other software as well. Same problem persists.
Any ideas, guys? Thanks in advance.
First off a quick read of the documention in case anything catches your eye there
http://docs.piriform.com/recuva
How to run recuva in debug mode and the you could attach the log here in a post for the devs if you think there is a problem with it.
http://docs.piriform.com/recuva/troublesho...a-in-debug-mode
Also include you system specs and anything different about the way you have your system set up.
Welcome to the forum Manderz ![:)]()
