After installing CCleaner, my Vista started having problems. Programs will not open or open extremely slowly-sometimes as much as a half hour and then don't work properly. I am not an expert, so possibly I didn't install the program properly or chose improper options during setup.
These are CC's authentic download sites. If you downloaded from somewhere else, and your system is not performing normally, you may have a rogue imitation.
A genuine copy of CC does not drastically reduce system performance after installation.
Please Help
Woodrow have you actually run CCleaner yet or just installed it?
If you haven't run it yet then as kroozer says there's nothing in the CCleaner installation that should cause a problem.
If you have run it what options did you select? Did you do a registry clean and if so did you back up the entries
