Udating issue
Hello,
When notified about an update on my home computer, I click on update and suddenly Microsoft Word 2010 starts loading over the ccleaner program. After loading, there's just a bunch of script displayed and can't update.
I've tried uninstalling ccleaner and reinstalling to no avail.
Any suggestions here? Thanks
Uninstall CCleaner and make sure you delete it from from Program Files afterwards if it is still there.
Reboot.
Then download CCleaner from here to your machine.
https://www.piriform.com/ccleaner/builds
Then install it.
Do you still have the problem?
What operating system are you using?
