with the new CCleaner i am having the following problems
where i the list of recovery programs for win 11, you could see how many you had and take some off
I dont want the icom to come up in the task bar in win 11, how do i stop this prorblem
Hi @bugs1,
CCleaner 7 currently does not have the Restore Points feature.
If you’d like to see this feature added to CCleaner 7 in the future, please submit your suggestion via the Ideas Portal, located in the left-hand menu of the application. This helps us gauge interest and prioritize enhancements based on user feedback.
You can remove any icon from your task bar by right clicking it and selecting unpin from the menu that appears.
I understand about the Restore points Feature
about the task bar problem…
i can not see where it is being loaded each time i start my computer Win 11, not in the “Ccleaner startup manager” or the Win11 “Startup Apps” HOW CAN I NOT START IT UP when i start my computer
once in the tool bar, there is no way to turn it off, below is a pic of what i see when i right click on the icon
Not
With CCleaner 7, we made a technical shift: CCleaner now runs as a Windows service instead of a regular startup app. This change supports new features like Performance Optimizer and Software Updater, and helps improve overall stability and performance.
Because it’s running as a background service, it no longer shows up in the startup list you could previously toggle in the UI.
We understand this is a change from how things worked before, and we’re here if you need help adjusting to the new setup.
OK i understand, BUT how can i take it out of the startup when i turn the computer on, and after looking at the pic i sent, how do i unload the program after i have used it. thanks for all the help
any idea when you will have an answer to my last post
OK no answer in 15 days……, great support……. next problem is that some days the program loads when i start up the computer and somes times it does not load……. JUST ADD TO THE LIST
