Trend Micro problem
Just downloaded the new version of CCleaner pro and the program will not execute.
Can you help?
Thank you so much
What antivirus do you use? There is a known issue with trend micro and McAfee that causes this issue.
13 minutes ago, Nergal said:
I use Trend Micro
What steps are necessary on my part to resolve?
You could try installing the Trend Micro upgrade.
https://esupport.trendmicro.com/en-us/home/pages/technical-support/maximum-security/home.aspx
Or whitelist CCleaner
https://community.ccleaner.com/topic/57702-ccleaner-not-working-after-update/?tab=comments#comment-317617
Thank you!
How do I whitelist CCleaner?
See in the link I posted
		Thank you!
Thank you from Ontario Canada!
It's fixed thanks to you - Very Very much appreciated - Gary
