Hello, I'm using CCleaner /AUTO with my small application (c#). But I have a problem. When CCleaner starts cleaning, CC's tray icon is appearing in the tray (SS attached). And It deselects the active window.
So, How can I disable this tray icon? "Advanced menu option" is not working for my problem.
There currently isn't a way to disable it. What you want could be considered a feature request/suggestion so there'd be the ability to enable/disable the tray icon.
