Translations issues
Multilanguage version of Recuva have some problems. Some translated strings aren`t showed totally in main window of Recuva.
Bug or I must minimize some strings?
In CCleaner v2 translations various strings are bigger than in English and CCleaner shows it correctly....
Can you post a screenshot of this?
Thanks
MrRon
Thanks
MrRon
Since we are in this thread, i suggest to shorten the "This file is overwritten with" sentence.
Eg. changing it with "File overwritten with" or "File overwritten by" or simply "Overwritten by".
The strings under 'Comments' column are very often cutted, also enlarging Recuva to full
screen mode (consider i own a 20" widescreen monitor) :)
String ID: 108
Issue: "Modo de"
Correct: "Modo de exibi??o:"
String ID: 113
Issue: "Para maiores informa??es, favor"
Correct: "Para maiores informa??es, favor visitar:"
These 2 strings will be fixed in the next release.
MrRon
