Tools: System Restore "All selected Restore Points will be removed" warning
When I go to Tools > System Restore and choose my oldest one or two Restore Points to be removed, I always get that warning pop-up that says something like "All selected Restore Points will be removed." That warning is accompanied by a Windows system-set "Exclamation" sound.
I would like to find a way to disable the warning pop-up (and its alarm sound), because I know perfectly well what I have asked CCleaner to do, and the warning is OK the first few times, to give inexperienced users a heads-up, but those of us who use the function every day and understand it should have a way to shut it off.
Is there a way to shut it off?
(In Settings (Advanced), "Hide warning messages" doesn't do it.)
BTW, shutting off the sound is trivially easy in Windows. It's the pop-up window I want to shut off.
