Tools - Statup - click enabled - make Yes's all go to top
I think it is stupid behavior in Tools - Startup - Windows, Scheduled Tasks & Context Menu tabs,
when you click Enabled, all the Yes's jump to the bottom and half are hidden.
Clicking enabled means you want to see which ones are enabled = Yes.
You should make all the Yes's group at the top straightaway after clicking enabled.
