So I was selecting items to be uninstalled (or so I thought) and I selected "Delete Entry" instead of highlighting the items and selecting "Run Uninstaller".
Now, I can't find the items I deleted so that I can uninstall them. How do I get the entries back that I deleted? I love the software but this was clearly a labeling issue for me. Please help, and thanks!!
Perhaps they are in add/remove programs list in the control panel.
Or try c/program files, open the software file you want to uninstall and look for uninstaller.exe
If still no joy, have you a sysytem restore point from just before you did this?
Thanks--they're gone from the Control Panel list too. I guess I have to remove them program, by program.
Wonder if they could be hidden from the windows add/remove list.
Try the tip below.
Windows Explorer>Tools>Folder Options check Show hidden files and folders.
Open sysoc.inf in the C:\WINDOWS\inf Then press Ctrl+H to open the Replace Wizard.
In Replace Wizard:
Find what: ,hide,
Replace with: ,,
Then go to control panel Add/Remove , if there were any hidden components they should now show.
There is always Revo Uninstaller, I've just seen a link to this on here, and its free. ![;)]()
