Timed Running of CClean
Not sure if this has been requested before...
I run CClean on a PC that automatically hibernates at the end of the day and comes out of hibernations the next morning, the issue is that CClean only runs when the PC is restarted unless I force it and in this case it may be weeks or months before I have to reboot the machine.
Can an option be added to run the application at a specific time, or after a number of days when it hasn't been run?
Ta
K
Using the /AUTO parameter via Windows Task Scheduler will do what you want.
Doh! The solution was staring me in the face! I use the scheduler to change the power settings so that the machine only goes into hibernation at the desired time.
Thanks
K
