seth
1
Win 7 - 64 bit home Prem
Thunderbird 15.0.1
CCleaner v3.21.1767
After running the cleaner I notice when I re-open Thunderbird, the Message Pane returns.
What option(s) in CCleaner will ignore the Message Pane (in other words I don't want the Pane view) ?
This has been discussed just a week ago.
Check http://forum.pirifor...howtopic=36827 and http://forum.pirifor...showtopic=35960
I just tested this.
Thunderbird / Session cleans session.json. Cleaning session.json closes open emails/emails in tabs and opens the message panel.
Using CCleaner v3.22.1800 and Thunderbird v15.0.1.
You can untick "Session" under Applications/Thunderbird, it cleans "session.json" and resets the message panel (in the bottom).
If you want to clean it and don't want the panel, you can just click F8 in Thunderbird which hides it.
IMO this ain't a bug.
